I remember my last house with its Lowest Bidder water heater...I ended up-
-wrapping it with so much insulation that I filled the closet it was in
-wrapping all the pipes twice, once with 1 inch and again with 1.5 and Gorilla tape
-turning down the thermostat until it was safe to run Hot only in the showers (having to mix Cold water into your Hot is just plain inefficient), and
-left the heater on all the time with no timer.
Now i'm in a Jayco travel trailer with a 15 gallon gas/electric tank, which I can't insulate further due to the pilot light and internally-routed hoses....so now my routine is-
-hey, I need Hot water! (flip switch on wall)
-wait 10 minutes
-use water, flip switch off
So....sort of timing these days...
