Old 04-11-2015, 04:01 PM   #36 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Cd View Post
Thanks Mech.
The A/C works fine. It's just that I avoid using it, so as not to burn a hole in the sky any larger than it already is.
I want to replace the R-12 with something less damaging to the ozone that protects us.
Any more guesses about what would cause the vent to blow stale warm air vs. cool air* ( *meaning the temperature of the air directly outside the car - I'm not expecting it to blow cold air ... just not hot air ! )
I cleaned out the fan as you guys directed, and you were right. There was indeed lots of leaves and crap in there.
It solved the problem of noise, and the air force seemed slightly better, but the air is still warm ( ????)
I think Mech called it. When these vents are set to "cold" (not AC) the hot coolant is not allowed jnto the heater core. If the valve clamping off circulation of hot coolant is failing, hot coolant will get into the heater even when you select "cold" vent settings.
Cd (04-11-2015)
