Old 04-12-2015, 04:19 PM   #11 (permalink)
renault_megane_dci
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
In my opinion it is all down to what the manufacturer meant for the bike.
Very high HP per liter engines usually waste fuel.
Recipe is simple : long duration camshaft with a lot of overlap, very short stroke for a lot of RPM, short inlet track for high RPM max power.
But the recipe for high FE is pretty much the other way around ...
Except for the general freer breathing
Then it's a matter of vehicle efficiency :
sports bike offer longer gearbox ratios and refined aero, top notch accoustic tuning of exhausts and inlets, state of the art injection and other fancy equipements.
My conclusion is, for a given capacity, less cylinders is usually better if you want to stick to sensible speeds.
