Old 04-14-2015, 12:59 PM   #2 (permalink)
darcane
darcane's Avatar
Do you have rear disc brakes? That vintage Silverado had a lot of trouble with the e-brakes sticking and debris getting in the calipers and causing odd wear, so much so that they eventually switched back to drum brakes. I assume the Burb would have the same problems if you had the rear disc brakes.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
The Following User Says Thank You to darcane For This Useful Post:
101Volts (04-15-2015)
