Originally Posted by thingstodo
...The clamp-on meter does not register a surge in current on the positive DC supply. And there is no output on the screen.
Any ideas, Paul (or anyone else)?
If i remember correctly. There is a loop in the code right at the start with a delay that waits for the throttle to be at minimum before continuing.
If you have it permanently set to 2.5v it is probably stuck in that loop waiting for the driver to take his foot off the accelerator before starting up.
High pedal lockout i think it is called.
That may be the issue.
