Originally Posted by Astro
If i remember correctly. There is a loop in the code right at the start with a delay that waits for the throttle to be at minimum before continuing.
If you have it permanently set to 2.5v it is probably stuck in that loop waiting for the driver to take his foot off the accelerator before starting up.
High pedal lockout i think it is called.
That may be the issue.
What would you suggest as a 'foot off the pedal' value for the accelerator?
I think Paul said the range was 0.5 - 4.5V ... so maybe 0.6V? I'll try that and see if anything changes.
