Old 04-17-2015, 12:33 AM   #17 (permalink)
Davo53209@yahoo.com
Originally Posted by firehawk618 View Post
For mounts to trans you'll find 9. 3 are on the front close to the radiator, 3 are up top looking straight down, one is close to the firewall right by the speed sensor and the other 2 are on the back of the engine. One you get from the top side, two from the bottom side.
For transmission to engine bolts there are 5. 4 of those you get from the top / transmission side. The 5th is under the car just above where your left axle shaft pops into the trans.
I find it easiest to pull the left axle shaft out of the way and if you still have an intake manifold support bracket remove it. That will give wide open access to the 3 bolts in that area *2 mounts, 1 bellhousing*.
It would appear that I've gotten all of the mount to transmission bolts, whereas I may have missed the one transmission to engine bolt hidden underneath the bracket towards the front. I will look at this again tomorrow morning.
