You can always rip out all the proprietary crap and install something like a megasquirt system.
You can run what ever sensors you want and edit your own code. Say you want faster response IAT GM sensor or say you need a bigger MAF but want to go with a cheaper Asian or Domestic MAF for your euro import. You can do that.
And you'll no longer be OBDii compliant which makes you technically emissions illegal. *assuming it's 1996 or newer*
