I had a Suzuki XF 650 Freewind single and loved it.
Best tanks on that were around 65 mpg - not hypermiling at the time, just steady pace cruising through Spain on a camping trip.
Having said that, FE was bad at highway speed (because of the short gearing) and city (because it was a bucking mule below 3000 RPM, so you always had to shift down even if you did not need the power).
Twins will allow a better ride at lower RPM (than singles) and may be more economical because of it.
