Old 07-25-2008, 12:23 PM   #348 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
If you are going to go with 12 12v cells, why not go up to 144V? You'll still have the amp hours avaliable, but twice the voltage. I understand the controller would cost more (unsure of actual price), but maybe its worth it?
Yeah, mostly the big consideration is cost. A Curtis 144V controller is $1400. A slightly used NEV 72V controller is 300.
Also, the motor I am using is originally designed for 36 volts. I will be running higher quality brushes in there, and eventually advancing the timing as well. I really have no idea how the motor would handle 144V.
I actually have considered the idea of using a PWM controller in combination with contactors to make a very controllable vehicle at lower speeds, and then having it kick over to a "direct connection" for a higher voltage "overdrive".
I wouldn't be able to use the controller when the pack is configured in the higher voltage configuration. It would just be a "cruising gear". Could be activated with a momentary on dead-man's switch - as soon as you let go of a button on the steering wheel, or trigger on the stick shift, it would drop down to the lower voltage, controller-run mode, which would give you full speed control over the motor again.
Another reason why I am thinking 72 volts is that I already have a high-amp 36 volt charger. I could rig up the pack to be split in half for charging (2 36V legs). For 144V I would need a big fancy 144v charger or a dozen 12 volts. That is just one more thing to add to the cost of the project.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
