Old 04-19-2015, 04:55 PM   #17 (permalink)
elhigh
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Originally Posted by WildLand View Post
What do you mean springs made from the actual belting? Just a piece the connects to the belt to the frame?
I mean use another piece of belting to serve as a spring behind your airdam (which would also be made of belting). Over a short span, like from the dam to the frame, the belting is relatively stiff but if you whack into something it'll give and spring back, so your dam survives the trail and still is useful on the highway.
