Old 04-19-2015, 07:52 PM   #19 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
May I summarize and see if any or all of you think I have a reasonable understanding of an implication of this discussion? Here it is: if a modded car such as mine runs higher than OEM spec psi in the tires and with less weight load on them than manufacturere had planned, then the deflection will be less than the engineers expected when designing the odo and speedometer. Add to all that uncertainty the fact that I am running tires different than the OEM tire. All that might explain my repeatedly observed approx 1.29% undercount in distance travelled relative to GPS.
