VTEC is essentially having two cam profiles optimized for different rev ranges, and usually the switchover is 4-5,000RPM. It wouldn't surprise me if most VTEC engines had better fuel economy (all else being equal) than their non-VTEC counterparts due to the lower-rev-range cam profile being tuned for lower revs, rather than aiming for the middle as is the case with a lot of Honda's non-VTEC designs.
As firehawk618 said, most VTEC engines (aside from the ones in the VX/HX models) are geared much shorter though, which probably accounts for most of the mileage differences.
