Old 04-21-2015, 01:28 PM   #43 (permalink)
jimmylomax
Red FIRE Racer - '08 Honda Fit Sport
90 day: 48.54 mpg (US)
Correction: I'm not looking at the injector fuse, but the ignition coil (fuse #33 on a 2nd gen Fit).
It worked smoothly when I tested it, no CEL. Once it gets up to the top of my List of Things To Do, I'll see how CEL friendly it really is.
Interesting. There is an "ignition coil front" as well as a "...rear". I guess I could pull fuses 7 & 9. I'd have to think the gen 2 would have the same number of coils.
Wiring Diagram
I'm curious how much longer fuel is injected from this method - in other words, how long from the time the PCM realizes ignition is dead until it cuts power to injectors - I'd guess not very long, but who knows. Do you notice it taking longer to rev down from your switch versus using the key?
