Old 04-22-2015, 09:44 AM   #22 (permalink)
xavi
carbon buildup
Mine doesn't buil up any carbon because I only use 2% oil, but if I use 3% it will probably build some...
I take the spark plug off every now and then, and give it a clean. and the center electrode is brownish as a good burn indicator should be. clean the little fresh oil, and with a steel brush I sand off the dry oil. but it was pretty decent with very little carbon...
