Old 04-22-2015, 06:47 AM   #21 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
For carbon build up, could you not play with a hotter spark plug ?
Old 04-22-2015, 09:44 AM   #22 (permalink)
carbon buildup
Mine doesn't buil up any carbon because I only use 2% oil, but if I use 3% it will probably build some...
I take the spark plug off every now and then, and give it a clean. and the center electrode is brownish as a good burn indicator should be. clean the little fresh oil, and with a steel brush I sand off the dry oil. but it was pretty decent with very little carbon...
