Old 04-26-2015, 12:42 PM   #28 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by oldtamiyaphile View Post
So your car sits at 12.8v as long as speed is below 40mph? ...
Yes. Unless the voltage or load crosses other limits/thresholds. And climbing hills at low speeds the voltage will sit even lower. It also will maintain a low charge in some conditions. For example, just before climbing a slow hill from a stop, my voltage meter shows say 12.34. I key on, begin the climb, flip the alternator switch on, and the charge climbs and stays only at 12.5 volts during the whole climb.
We're probably a little off topic for the OP though...
I think one message of the thread is probably that removing the belt is an option but not necessary, though it would be simple. You could do an alt on/off switch instead and have less range anxiety. Whether you remove the belt or install a switch, get a deep cycle battery and a plug-in, on-board charger with a capacity 50% or more of the amp hour rating of the battery.
The donkey CRX (04-26-2015)
