Old 04-28-2015, 01:18 PM   #31 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by oldtamiyaphile View Post
I'm really impressed Honda were doing it all those years ago. Do you know how the alt is controlled? I wonder if it could be a simple retrofit for 'dumb' units. Based on my experience with 'smart' alts, there's a good 5% gain to be had with no drawbacks.
I think you might need the ECU as well as the Electric Load Detector unit (ELD). Daox is probably correct that it is a bit more complex. There are several wires into the alt... a 4 or 5 pin connector, IIRC. In fact, even with my switch, once I turn the alt on, putting the switch back into off does not shut the alt down, inly cutting the engine will do that. Works well enough.
J
