Old 04-29-2015, 11:44 AM   #98 (permalink)
BabyDiesel
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
Originally Posted by MisterMundane View Post
i was hoping to gain about 20 MPG lol.
jk
sad to see my average dropped substantially from all the idling and crap while i was doing all the wok on the car. now I have to work extra hard to get it back up. this next tank wont be very good.
also going to take home some aluminum sheets from work, to maybe start working on an underbelly. decrease some drag maybe.
oh, ill also add, i saw a few times 500 range of coasting in nuetral for instant MPG. thats awesome! average is around 280-350, but it has momemnts where it jumps up 400+
going to check my air pressure today when I fill up, as they seem a little low. If i bump that up a bit it will help
You'll gain 20 mpg with the water pump fixed and three ecomodder stickers
Underbody panels are good, as the underside of our cars are usually aero-dirty. I did just the front and rear of my Escort and I saw a big improvement. I was actually able to gain MPG from P&G lol.
I think the IAC valves from ford are funky. I've had mine go from 100 to 600 in one drive
Pump them tires up! Try sidewall max and see what you think, I preferred that over placecard. And that is when I still pushed it hard at times I now run 60 psi, buutt I'm over the top!
quick question, does the fuel tank calibration have an effect on the MPG readouts? I keep forgetting to tell it i filled up after leaving the gas station, so even when im full it will yell at me that its almost empty. I'll try to get better at remembering, but does it affect the MPG numbers at all?
if it doesnt, ill just turn those stupid alarms off and ignore that feature.
Short answer, it does. Telling the UG that you added more fuel than you did will cause instant readouts to be lower than actual, and vice versa. The advice given to me on here is when you get the sorry thing calibrated, LEAVE IT BE! If you add 0.5 gallons more than the gauge says, but your mpg figures are spot on, don't tell it you added that fuel and throw off your readings.
I had this happen when I had an over fill at a different pump than I usually use, then drove with my SG telling me I was having a hard time breaking 40, when I know I was! Went back to "my" pump (YKYAEW...) and fixed the calibration, along with scoring about +2 mpg over what SG was telling me
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
