Slowing down will be your friend in that monster. I'm sure if you keep to the speed limit or just under you should hit your numbers with no issues.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
