Old 05-02-2015, 09:57 AM   #50 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Because these engines have a traditional distributor and not electronic ignition, I'm not sure if the computer would see any difference if one is adjusted differently. Perhaps, though.
The sixth gen distributors also have an electronic igniter build into them... their not entirely traditional.
On the question about aftermarket gauges and reading ignition timing... The ultra gauge will reveal timing advance too, but you shouldn't use it to check actual mechanical timing, nor to set timing. You'll need a timing light and the marks on the crank pulley.
Hope that helps.
James
