Old 05-03-2015, 02:30 PM   #2 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Cold start this morning, it idled raggedly in open loop, and then steadied at idle in a few seconds once the UG indicated closed loop operation... at the same time the trim started getting lean. It stabilized in the negative teens (-14 to -18%).
Once warmed up it stalled once while coasting with the engine on in neutral.
There was one episode where the primary O2 reading on my UG showed voltage 0.995 for something like 5-10 seconds straight with no flutuation.
Warm, the engine generally idles comfortably in the 600 rpm range, with a fuel trim -24% or so. Sometimes it idles almost at normal 0.00 fuel trim.
