Old 05-03-2015, 03:51 PM   #3 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
more reading, more thinking outloud
Maybe I can rule out the vacuum leak idea, because if the ECU is reducing fuel the must either be more fuel getting into system than ECU expects or less air. A vacuum leak would mean more air getting into the system, which the ECU would adjust to by adding fuel, not subtracting it.
Maybe I can also eliminate the O2, since the problem occured during open loop in cold start this morning. In closed loop the idle stabilized as the system detected a rich condition and took away fuel. Maybe eliminate the MAP sensor too, for the same open/closed loop reason.
This leaves fuel injection or a fuel leak from somewhere.
