Old 05-03-2015, 10:44 PM   #28 (permalink)
redpoint5
90 day: 38.47 mpg (US)
Originally Posted by P-hack View Post
Separate concerns, and applications.
1. A house doesn't need the same power density battery as a car.
True. However, if a vehicle already has enough energy to supply the house in an emergency, then the extra expense of a separate house battery is unnecessary. While some people may find it worthwhile to have a separate house battery, those with more modest budgets would be best served to have their car battery pull double-duty.
2. A car needs to be charged to be useful, can't drain it overnight and expect to drive it the next day.
Intelligence must be programmed into the system so that the vehicle owner can specify the depth of discharge before the vehicle stops supplying energy to the house/grid. The utility should provide an economic incentive for the customer to volunteer a portion of the vehicles electricity, but allow the customer to determine what portion is needed for their driving needs.
3. The house should still function when the car is not there (and have batteries available for storing daylight energy).
Necessary for an off-grid home, but the vast majority of customers are on-grid. Schedule the vehicle to charge off-peak, but volunteer the vehicle energy to cover peak demands.
If anything the house needs a much larger battery, so it can charge the car overnight when it is home from energy stored during the day and supply the household needs overnight.
Peak leveling is more economically accomplished on a large scale. For off-grid, a battery is a necessity. For the majority of customers at the moment, a large-scale peak leveling mechanism is cheaper. Plugging in an EV to the grid is just an extra benefit to leverage a resource that already exists.
