Old 05-04-2015, 08:09 AM   #13 (permalink)
KFM
KFM's Avatar
Terminator - '00 Honda Insight Base
Gen-1 Insights
90 day: 72.78 mpg (US)
High Voltage - '12 Chevrolet Volt
Team Volt
90 day: 108.44 mpg (US)
This sounds excellent! I'm gonna reset my trip and drive this rest of this tank without using any assist and see what kind of mileage I get.
I just grid charged my battery this weekend, and immediately lost a bar after using some assist, got it back, and lost it again after using it. Grid charging didn't seem to help my battery at all, this time.
How far did you end up driving it with it installed? I saw in your YouTube video that you had driven it around 20 miles, at that point. I assume the car will drive pretty much just like it would if the clutch interrupt switch is depressed? Also, can you still use air conditioning without the IMA? My assist pretty much kicks in immediately when I turn it on.
Originally Posted by retepsnikrep View Post
It's also possible to drive the SOC gauge on the dash with 19 bars soc or whatever you want with the addition of an RS485 line driver chip.
You could also drive the IMA light to mimic the start up sequence for that as well.
If you wanted to do both of those then we need a slightly bigger pic.
I like this idea, it'd almost be like nothing changed for me, except having less power.
