Old 05-01-2015, 01:39 AM   #11 (permalink)
Programming Peter's Pic Gizmos - Insight Central: Honda Insight Forum
Old 05-03-2015, 12:13 AM   #12 (permalink)
It's also possible to drive the SOC gauge on the dash with 19 bars soc or whatever you want with the addition of an RS485 line driver chip.
You could also drive the IMA light to mimic the start up sequence for that as well.
If you wanted to do both of those then we need a slightly bigger pic.
The Following User Says Thank You to retepsnikrep For This Useful Post:
KFM (05-04-2015)
Old 05-04-2015, 08:09 AM   #13 (permalink)
KFM
KFM's Avatar
Terminator - '00 Honda Insight Base
Gen-1 Insights
90 day: 72.78 mpg (US)
High Voltage - '12 Chevrolet Volt
Team Volt
90 day: 108.44 mpg (US)
This sounds excellent! I'm gonna reset my trip and drive this rest of this tank without using any assist and see what kind of mileage I get.
I just grid charged my battery this weekend, and immediately lost a bar after using some assist, got it back, and lost it again after using it. Grid charging didn't seem to help my battery at all, this time.
How far did you end up driving it with it installed? I saw in your YouTube video that you had driven it around 20 miles, at that point. I assume the car will drive pretty much just like it would if the clutch interrupt switch is depressed? Also, can you still use air conditioning without the IMA? My assist pretty much kicks in immediately when I turn it on.
I like this idea, it'd almost be like nothing changed for me, except having less power.
Old 05-04-2015, 01:33 PM   #14 (permalink)
Yes you can use the air con.
I only drove it around 20 miles as I hate the car without the IMA so only fitted it for testing purposes.
I don't intend to do any work on the schematic/code for driving the IMA light and soc gauge unless some people actually buy and use it.
The schematic I have published works fine as is.
Insight for life (05-04-2015)
Old 05-04-2015, 03:20 PM   #15 (permalink)
Insight for life's Avatar
05 Prius (wife's) - '05 Toyota Prius package 5
90 day: 44.32 mpg (US)
Citrus - '00 Honda Insight
Gen-1 Insights
90 day: 60.68 mpg (US)
This is something I am very interested in and would like to thank you for you contributions to our community!
Old 05-04-2015, 07:45 PM   #16 (permalink)
I don't think it's necessary as no one in inspections knows or cares if the IMA should blip on startup or how many bars soc you have. Best to leave it as is so potential future buyers will know whats up.
Does it come with instructions on how to build and install?
Are you certain you can lean burn with this while the battery is removed? I heard the car needs to have the IMA battery to be able to leanburn. If so i want to buy one.
I try to be helpful. I'm not an expert.
Old 05-05-2015, 01:06 AM   #17 (permalink)
The instructions (schematic) are in the thread on IC.
ASFAIK it lean burned fine when testing.
If it doesn't then if you send it back you can have your money back.
MobilOne (05-05-2015)
Old 05-05-2015, 08:37 AM   #18 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Originally Posted by sheepdog 44 View Post
The overall experience is good and highway performance is unchanged and possibly better. IT does much better up extended mountain climbs on the freeway. Vtech will kick in, where as with the IMA the battery would discharge halfway up and force regen up the other half making the car feel like a pig.
You might be happier installing a MIMA which would allow you to cut out the IMA for those long climbs, and then drop it back into the mix when you're done with the mountain.
+1 on pig. I have a 1.5 mi. climb on my way home and an IMA light showing, the batt capacity is down to maybe 40% of new. Regen during climbs bites hard. And no, I don't have a MIMA either.
Old 05-09-2015, 12:24 AM   #19 (permalink)
Well to put my money where my mouth is I will send the hex code free to the first person who actually builds and tries one and reports back on here
Post a picture of it built/installed and ready to go and I'll send you the code FOC!
The free code will be personalised to only run on your chip.
Old 05-20-2015, 02:42 AM   #20 (permalink)
No takers on the free code offer. Oh well
