Old 05-04-2015, 07:45 PM   #16 (permalink)
sheepdog 44
Originally Posted by retepsnikrep View Post
Yes you can use the air con.
I only drove it around 20 miles as I hate the car without the IMA so only fitted it for testing purposes.
I don't intend to do any work on the schematic/code for driving the IMA light and soc gauge unless some people actually buy and use it.
The schematic I have published works fine as is.
I don't think it's necessary as no one in inspections knows or cares if the IMA should blip on startup or how many bars soc you have. Best to leave it as is so potential future buyers will know whats up.
Does it come with instructions on how to build and install?
Are you certain you can lean burn with this while the battery is removed? I heard the car needs to have the IMA battery to be able to leanburn. If so i want to buy one.
I try to be helpful. I'm not an expert.
