Old 05-05-2015, 12:46 PM   #173 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Clean the electrical ground connections. I had all kinds of haywire sensor and fuel trim activity. It seemed patterned, like you are describing. I considered injectors, MAP, O2, and spark wires... in 30 mins with 210 grit sand paper, a cloth, and a little red grease, I cleaned the engine ground wire connection surfaces and those for the battery ground and the transmission ground plus a little one I found along the way... all problems vanished. I'm still in disbelief.
Given the color of the AT tranny fluid, I'll bet ground have never been cleaned.
Good luck.
james
