Old 05-11-2015, 06:55 AM   #21 (permalink)
sendler
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
So you would rather have to lube a chain every 500 miles? Which for you is every other day. Than do nothing but just ride a belt? Based on your experience with the mediocre fuel efficiency of the Burgman, you are under a preconception that you would have to change gearing on the PCX (Which is available via DrPulley sliders in the vario for $40 or final drive gear set for $150). Is 93 mpgUS not good enough?
There are no high efficiency shaft drive bikes.
Michelin City Grip tires will last 30,000 front and 18,000 rear. Tire cost for a PCX will be slightly less than a car. But it will use half of the gas of a Prius and costs 14% as much to buy. You can find used ones all day long for $2,000.
The only other highway capable bike that can approach 90 mpgUS is the CBR250R if you really want to shift gears.
