Old 05-12-2015, 12:14 PM   #23 (permalink)
sendler
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
Originally Posted by The Atomic Ass View Post
Lube? No. Dry chains last longer, as they don't collect as much garbage. Any o-ring or x-ring chain has all the lubricant it needs sealed into where it needs it. Keep chain clean, and no problems.
You have many strong preconceptions so there is no point in me discussing this with you any further. Good luck getting a chain and sprockets to last more than 5,000 if you never lube it.
Sliders don't really make a difference in the min/max ratio's, but merely how fast the transmission shifts through those ratios. .
Again you have apparently never really read up on how the DrPulley sliders work to increase gear ratio on both ends. Engineering genius, where each surface dimension is optimized to do it's specific job. Unlike a round roller. Very cool design. I wish i had thought of it. And they last forever.
Burgman 400's are showing about 60 mpgUS on Fuelly.
Suzuki Burgman 400 Mileage | Fuelly
Air cooled is usually better on fuel economy due to the much higher cylinder head temps and no parasitic drag of a coolant pump but they make less power and are less reliable.
