Old 05-13-2015, 05:28 PM   #15 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by WD40 View Post
Do you reset the ecm?
If you do it might take while for the cars issues to show up.
It's a good question. On the second repair with the pressure regulator, I did not reset the ECU (I left the battery connected) and the problem still went away. Then, another time, all I did was reset the ECU by disconnecting the battery for an hour or two. But that did not get rid of the problem for even a moment. When I cleaned the grounds, the ECU was of course reset.
Weird, huh?
