Old 05-14-2015, 07:31 PM   #14 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Just curious, if you just put in a complete manual transaxle, shifter, clutch and cables and left out the sensors and the rest of the wiring crap wouldn't you just get a no lean burn insight that doesn't shutoff and have a cel?
Originally Posted by Red View Post
You could, you'd need a few parts which isn't easy to find for an Insight
For starters
ECU
Cluster
Shifter
Shift cables
Trans
Flywheel
Clutch
Trans sensors (5ish or something)
Part of the harness that hooks up to those sensors
And since you'll be swapping in a manual trans ECU might as well hook up the Lean Burn stuff so
LAF sensor
New cats with the right ports
Extra bits of harness
IMO too much work and $$ to be worthwhile unless you have most of the stuff on hand or you could pick up a parts car cheap
