Old 05-14-2015, 10:55 PM   #204 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Fellow Ecomodders a little update. I got my car running again, it has been a major pain this go around!!! I have been having lifter issues, oil leaks and ecu problems.
I forgot to bleed my lifters with the new revised head and had lifter pump up. So I upgraded while the valve cover was off and put in 3g lifters.
Had the typical oil leaks on the new build and had to order a new low pressure turbo return gasket.
My ecu is doing something weird again. I had it rebuilt last year because of leaking caps. It was sending voltage to the ecu cover housing. About 3 volts??? Anyway it started doing it again so I unbolted from the dash and now its laying on the passenger floor again. I have know idea whats going on here??? But it runs fine as long as it doesn't touch any of the metal of the car???
I got all the hoses attach again. It looks like a vacuum hose nightmare.
I'm going to need three extra co-pilots just to run this thing. lol
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
California98Civic (05-14-2015)
