Old 05-15-2015, 12:46 AM   #37 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I'll add my story here now that I'm back on the list after letting the Nut Wagon rest over the Winter.
My driving technique is low RPM (under 2000 RPM), low speed (40-45 MPH), and a lot of engine-off coasting down hills and to stops. I don't do pulse and glide on flat roads. I try not to brake or idle.
The 1991 Civic Wagon running the original 1.5L 16-valve engine, but half the rocker arms have been removed, turning it into an 8-valve engine. And I have a CRX HF transaxle that keeps RPM low. Plus a lot of little stuff that adds up. Full mod list is in my garage.
To keep my numbers accurate, I burn full tanks. And I've checked my odometer via GPS and adjust the odometer reading to reflect actual distance.
I use no MPG instrumentation. Mostly because MPGuino won't work with my TBI.
Details: Nut Wagon - 1991 Honda Civic Wagon DX Fuel Economy - EcoModder.com
1991 Honda Civic Wagon DX Gas Mileage (Nut Wagon) - EcoModder.com
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following 4 Users Say Thank You to Gasoline Fumes For This Useful Post:
BabyDiesel (05-15-2015), Chrysler kid (06-04-2015), niky (05-16-2015), PaleMelanesian (05-18-2015)
