Old 05-15-2015, 01:28 AM   #30 (permalink)
The Atomic Ass
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 38.64 mpg (US)
Originally Posted by sendler View Post
DrPulley sliders do actually change the top ratio on many scooters including the PCX. The stock rollers run up against the end of the ramps before the pulley halves are touching, forming the limit of travel. There is always virgin metal that the belt never touches on the outer portion of the front pulleys with the rollers. The sliders are thinner at the side that comes up against the end of the ramp so they travel out further, moving the variator through additional range of motion to take the belt all the way out to the edge. It is a cheap and easy 7% increase in top speed at redline and the stock 18gm weights are too heavy anyway. My 12 gm sliders pull at about 7,900 rpm. 11 gm might be even quicker with the rpm even closer to the 8,300 rpm power peak.
There are a couple final drive up gear kits available but I am content with a 71 mph top speed and 100 mpgUS on 55 mph back roads for now. If I want to run 70 on the highway to work, I take the CBR250R and get 90 mpgUS.
I think you might find that the DrPulley's do as I described: make the variator stay in it's highest ratio even when max throttle is applied.
Though, I'm willing to concede the possibility that the PCX is different from the Burgman. (I honestly don't know) On the latter, the pulley's simply did not move far enough to use up this virgin metal. I removed the rear spring to see how far they do move, and it's to the edge the belt makes in the pulleys, no further.
