Originally Posted by Daox
.....I'm not sure why I'd need a ballast? These LEDs run straight 12V power coming off the battery. They shouldn't be seeing any voltage spikes.
it's not a ballast. it's this:
DC11-35V to 11-35V 10A Constant Current Constant Voltage Boost Converter Step-up Power Module. put in 12v and only 12v output. my alternator runs between 13.3-13.7v depending on it's needs.
http://www.dx.com/p/dc11-35v-to-11-3...3#.VVaAYJNtGQw
this one is adjustable. these LEDs are already overclocked, reason life is not as long as others with lower output.
ebay has some too:
http://www.ebay.com/sch/i.html?_odkw...Power&_sacat=0
just make sure to match amp/watt.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
