05-13-2015, 06:43 PM
#11 (permalink)
Moderator
Originally Posted by Daox
What bulbs did you go with?
They were from some vendor on Ebay. They were specced as 6500K and 1800 lumens and cost me around $80/pair, if I remember right. When/if I need to replace them, it looks like I'll have better and cheaper options now, so that's encouraging.
The Following User Says Thank You to Vman455 For This Useful Post:
05-13-2015, 08:06 PM
#12 (permalink)
Not banned yet
Blue - '03 Chevy S-10, LS
there a lot of options. start an account on alibaba and most times shipping is included.
HB2 LED
also dx.com has good prices.
headlight led - Free Shipping - DX
i have purchased from both.
i am interested in the output.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
05-13-2015, 08:40 PM
#13 (permalink)
5 pin sensor
My question is do they have a dual function, so high beam and low beam.
I would definitely like to reduce alternator drag so please share your findings
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
05-14-2015, 02:44 AM
#14 (permalink)
I've been looking at these LED bulb replacements for a while, but always held off for fear of unknown longevity and reliability. So I'm interested to hear any real world experience.
How hot do the heatsinks get, for example?
05-14-2015, 08:56 AM
#15 (permalink)
Yep, its right in the specs in the first post. They have a high and low beam. They both put out 2400 lumens, they just shift the light position in the housing (by illuminating one or the other LED) to shift the light pattern.
05-14-2015, 08:57 AM
#16 (permalink)
I can test the heat issue when I get them.
I agree, longevity and reliability are my main concerns too.
05-14-2015, 06:37 PM
#17 (permalink)
Lots of Questions
Daox, can you also take some pics of the light cutoff and the color? I usually like the 5k color temp. but every manufacturer has their own version of color temp. Also, it would be nice to see a good cutoff, so we're not blinding anybody.
Thanks!
EDIT: You should also consider getting a ballast. That will help with the longevity of the bulbs as well as keep them from flickering at a noticeable rate.
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
05-15-2015, 08:42 AM
#18 (permalink)
Yes, I'll be taking pictures of the install along with the beam patterns, etc. Any specific requests?
Also, if anyone who is camera savy could tell me how to properly setup the camera for a night shot I'd be quite thankful. Comparing lights can be tricky and I'd like to get it as accurate as I can.
I'm not sure why I'd need a ballast? These LEDs run straight 12V power coming off the battery. They shouldn't be seeing any voltage spikes.
05-15-2015, 12:02 PM
#19 (permalink)
Hypermiler
Interested in how these turn out.
I'd like to see a photo of one OEM bulb and one LED side-by-side against a wall. That way we can see them under the same camera settings. It's hard to get a good representation, but this way we can see the differences between them.
The Following 2 Users Say Thank You to PaleMelanesian For This Useful Post:
05-15-2015, 01:51 PM
#20 (permalink)
You would need a camera capable of full manual control to set the shutter speed, aperture, and ISO. Otherwise the camera will adjust those settings based on light conditions and you won't be able to compare brightness from one photo to the next.
If you don't have a full manual camera, just take a picture of 1 LED bulb and 1 stock bulb at the same time. That will at least show the relative brightness.
