Old 05-17-2015, 11:36 PM   #22 (permalink)
lilwilly75
lilwilly75's Avatar
The Pious - '10 Toyota Prius Model II
90 day: 48.61 mpg (US)
In order to get the seats in you have to remove all brackets, slides, and guides from the lower seat. This also will split the seats into two separate piece that you reassemble with your EG lower assembly. These are all the parts I removed from the CL seats. Total time start to finish was 4 hours. The first one took almost three trying to figure out how it was going to come apart
The Following User Says Thank You to lilwilly75 For This Useful Post:
RPM (05-18-2015)
