Underbody aero panels may not matter if your typical driving is stop & crawl!
Did you happen to try out the manual? I ask only because its competitor the Mirage has literally the lightest, easiest to use clutch I have ever driven. I tell people that even hardcore city driving is hardly a reason to pass it up. But we don't get the Brio here, so I don't know about its clutch.
Does the car come with a fuel economy computer? Tracking the numbers in your daily commute and per tank is the first step. Up the tire pressure, and as deejaaa says, minimize idling as much as possible (though that may be a challenge... I imagine it's a little warmer in Jakarta than I'm used to, and A/C doesn't operate with the engine off).
Welcome to the forum! Make a garage entry and start a fuel log.
Darin
