Old 05-18-2015, 11:29 AM   #210 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Update:
Been driving the Talon around need to change a few things.
First I need to raise up the car its way to low. So going raise it up another 2".
I had to change some charge pipes around, my passenger front tire was hitting the charge pipe.
I also did some testing without the turbo box. The cars mid mount low turbo is extremely noisy and very hot. So the box is doing its job keeping the noise down and keeping me cool.
I'm also going to change the valve cover bolts to studs. I have had the valve cover off and back on probably twenty times all ready adjusting my valve system that promotes swirl.
The hot EGR is going to have to go. I blew out the vacuum diaphragm from high boost 45+ psi. So I'm going to have cold EGR only.
Good news no oil leaks. This is awesome considering its a DSM.lol Also engine delta p is .5psi for the good at 1 lb of light load freeway.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
user removed (05-18-2015)
