Old 05-18-2015, 11:01 PM   #30 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Car ran so poorly by the time I got home today it would shudder as I accelerated, fuel trims got as lean as -29%, and in the driveway I was able to idle it until it stalled. The computer took the car out of closed loop and ran it in open loop. So I got out the mitivac vacuum gauge and my scan tool, figuring I would measure vacuum mechanically and via the MAP sensor in inches Hg simultaneously. But first I tried three suggestions from this list: I hunted unsuccessfully for a ground wire on the intake; I sprayed water onto the hot engine to mimic rainy day humidity (no improvement); and I wiggled/pushed every wire and connector I could remember moving or brushing in previous efforts at repair. I also wiggled a couple others in the EVAP canister (I think).
That wiggling suggestion worked! The car runs perfectly normally again.
