Old 05-20-2015, 12:55 PM   #220 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by California98Civic View Post
Can it be lowered at all? It is high enough that a lowering of an inch or so might bring a modest aero benefit (for both speed and FE). Do you have an undertray or airdam? Car would go faster, farther with some of these mods, no? Little change to appearance. Any plans?
I can drop it about 2" more from the pic above. I have a few concerns with it when it was that low though. The biggest problem is our local driveways around here. So many are very steep and I kept hitting the front tow hook (even my own drive way I hit when coming over the drain path). My other concern is my charge pipe needs to be higher at the fire wall. So I need to ponder this for a while. I might bring it up into the cabin under the center console? The other thing that I could do is a skid-plate / undertray with a front air dam like you suggested? This would protect all the charge pipes and improve aero?
Anyway I need to rethink the ride height. lol
Pressure Gradient Force
The Positive Side of the Number Line
