Old 05-19-2015, 08:57 PM   #211 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Took the Talon for a drive today after the coil height adjustment. I need to start driving the talon more now because my newer 2013 Chevy truck has a miss-fire??? I think its a bad EGR???
Anyway I like the new ride height. What do you guys think??? Its still low enough for good aero but now clear most driveways.
Pressure Gradient Force
The Positive Side of the Number Line
Old 05-19-2015, 09:00 PM   #212 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
It looks sinister and i like it!
oh btw, ride height looks good too! Do you have a side profile shot?
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
The Following User Says Thank You to jedi_sol For This Useful Post:
pgfpro (05-20-2015)
Old 05-19-2015, 09:25 PM   #213 (permalink)
Growin a stash
Yeah that looks mean. It's a sleeper.
If I were you, given your free fuel situation, I'd drive the Talon as much as possible.
2023 Chevy Bolt
Previous:
2015 Nissan Leaf S, 164 mpge
The Following User Says Thank You to ME_Andy For This Useful Post:
pgfpro (05-20-2015)
Old 05-20-2015, 12:43 AM   #214 (permalink)
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
How I feel about seeing your Talon -
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
The Following User Says Thank You to BabyDiesel For This Useful Post:
pgfpro (05-20-2015)
Old 05-20-2015, 12:58 AM   #215 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
I will get a side profile shot tomorrow. Thanks again for the interest.
Old 05-20-2015, 01:00 AM   #216 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Still working out the final design on the recycle solvent system. I should have it done by the end of this month?
Old 05-20-2015, 01:17 AM   #217 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
One more thing I wanted to add that I luck out on is the leak down readings.
With the engine cold I have around 15% leak down. At normal operation temperature its around 2% leak down. So I'm very happy with the results.
I gap the rings at .021 on the top and .023 on the second. So this is pretty much normal from my past experience with wide ring gaps. The engine has less then stock blow by so I'm very happy at this point.
The engine is very responsive and has decent lean burn acceleration at mid load.
The compound turbo system is doing its job so far. I'm making boost from a dead stop about 4 psi at 22+ A/F ratio. No miss-fire.
The Following User Says Thank You to pgfpro For This Useful Post:
BabyDiesel (05-21-2015)
Old 05-20-2015, 11:11 AM   #218 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Side shot.
Old 05-20-2015, 11:37 AM   #219 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Can it be lowered at all? It is high enough that a lowering of an inch or so might bring a modest aero benefit (for both speed and FE). Do you have an undertray or airdam? Car would go faster, farther with some of these mods, no? Little change to appearance. Any plans?
Old 05-20-2015, 11:55 AM   #220 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
I can drop it about 2" more from the pic above. I have a few concerns with it when it was that low though. The biggest problem is our local driveways around here. So many are very steep and I kept hitting the front tow hook (even my own drive way I hit when coming over the drain path). My other concern is my charge pipe needs to be higher at the fire wall. So I need to ponder this for a while. I might bring it up into the cabin under the center console? The other thing that I could do is a skid-plate / undertray with a front air dam like you suggested? This would protect all the charge pipes and improve aero?
Anyway I need to rethink the ride height. lol
bio fuel, lean burn, turbo compound
