Old 05-21-2015, 12:51 AM   #222 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
This weekend I'm going to start on my second version of my single intake opening valve system with solid lifters. I built a very simple system that holds four of the intake lifters in place with no rocker arms on them, this keeps them from popping out under hydraulic oil pressure. So now I have a single intake valve per-cylinder to promote swirl for ultra lean burn operation. This will also help with engine delt p by increasing intake boost pressure from a more restrictive valve area.
The only downside to this is the fact when I want full maximum performance I will have to pull the valve cover and remove the lifter holders, and put the rockers back on. I will also be experimenting with the exhaust valves also.
Pressure Gradient Force
The Positive Side of the Number Line
The Following 2 Users Say Thank You to pgfpro For This Useful Post:
BabyDiesel (05-21-2015), Daox (05-21-2015)
