Old 05-21-2015, 06:28 AM   #14 (permalink)
cRiPpLe_rOoStEr
Originally Posted by PremierSprinter View Post
I understand what you are saying. Are these components meant to stay on or get switch on from a timer via 110v wall outlet or do they come on when you start the car to help heat it?
They're not meant to be plugged in a wall outlet, just run at the battery like a conventional glowplug.
I briefly touched up on it in my original post, but I intend to coil tubing around the downpipe to flow coolant through. The main purpose of this was to aid in warm-up and to help maintain temperature. My first TDI had the EGR cooler deleted and I couldn't get up to temperature before making it to work.
Nothing might prevent you to use both devices.
