The fact that you used "two lousy hundredths" as the title cracked me up
Originally Posted by aerohead
*AEROCIVIC might get in trouble in many states due to the mirror delete.If so,with the restoration of the driver's mirror,the Cd might be 0.177.(fabulous still!).
ECOSCORT might get in trouble as well, since I have no side mirrors
I am legal as far as the state of NC is concerned. And wow, I did not realize how much side mirrors affected the Cd!
*To get to Cd 0.15,or below,Hucho is going to tell you to do more elongation and perhaps do an active diffuser which can be lowered on the highway.
*An inflated tail would be one approach,as it's only deployed for the highway.
Here's a pictorial thought experiment with one
I recall that if the template was followed exactly on my car, the total length would reach between 20-21 feet! That is longer than an extended cab long bed Chevrolet Silverado, but it is still shorter than this -
How is that for elongation??
An active diffuser, hmm... what is wrong with a set height diffuser that is low enough for good aero,flexible enough to withstand city driving and rigid enough to survive 60 mph?
The inflatable boattail is a wonderful thought! I am unsure how to implement it in the real world. I'll think on it and weigh between it and the rigid tail.
*If you'll do everything to the Escort as AEROCIVIC,and then push a little harder,then you've got a shot at it.
*'Fix' your suspension at some attitude,then design the bodywork close to the template at that inclination.Mockups of body parts can be tuft-tested as you go to check for separation.When they show 'clean' flow,you can commit to that part knowing it will perform.
That is what I love to hear
I am planning on a 2" suspension drop front and rear, keeping the car as level as possible. I MAY try to drop it a little less in the rear so my belly pan acts as a diffuser. It will work out the geometry when that time is closer.
I actually have access to a smoke machine at my church
so I am tempted to borrow it and do a mock-up wind tunnel test! This will have to be on a super calm day, or even indoors. First thing I will have to do is see if the fog can even get thick enough to see and if I can get a fan to generate 50+ mph winds. I could make scale models and test them out easier.
Right know, I am trying to figure out how to attach tire boat tails to my car along with outer and inner side skirts, and it is more difficult than it first appeared. Then I want to redesign the rear fender skirts along with designing the front fender skirts!
...Gotta take it one day at a time...
