Old 05-21-2015, 11:28 PM   #228 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
My EGR explained.
One of our members had a question on my EGR. He ask how is your high boost killing the EGR Valve???
This is one of my EGR valves I was testing the exhaust pressure signal on.
This is the plate that I will use to block off intake boost pressure to keep it from killing the diaphragm in the EGR. I marked it intake and exhaust. Normally the intake hole is open. You can see by the way the EGR gasket is made.
I'm using a aluminum block off plate that I drilled a small hole into so the exhaust side can flow exhaust and I can get a pressure reading that I will use for data logging back pressure. Some how the 40+ psi is getting past the EGR stem? I didn't even have the hoses attach to the diaphragm and it still kills the diaphragm?
So now I have a copper cooling coil that then turns into a rubber hose that attaches to a boost regulator. I will be manually adjusting the amount of flow the EGR with the regulator.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
Cd (05-30-2015)
