Thread: False economy
Old 05-24-2015, 09:14 AM   #2 (permalink)
redneck
You guys trying to go beltless, what you save on fuel you spend on the 110-volt battery charger in your garage.
Wrong...
Plus you can't do roadtrips,
Belt can be re-installed for trips...
and if you can't enjoy your car, then why own one?
Really...
Then again, how can you enjoy anything under 200 HP?
The counter argument is... How can you enjoy anything over 200hp without breaking laws and or endangering others...???
Likewise, you guys trying block heaters, what you save on fuel you spend on 110V in your garage.
Wrong...
If you're using a good synthetic oil, then the block heater doesn't actually help reduce cold start friction.
False... A block heater among other things, allows a engine to reach normal operating temp faster. Thus reducing wear within the engine.
Electricity is very cheap per kilowatt hour as compared to petroleum.
Charging a battery or using a block heater uses less than 10 cents per day.
The Following 17 Users Say Thank You to redneck For This Useful Post:
92civicvx (05-24-2015), AndrzejM (05-25-2015), BabyDiesel (05-24-2015), changzuki (05-24-2015), drainoil (05-24-2015), Ecky (05-27-2015), fearone (05-24-2015), Frank Lee (05-24-2015), Insight for life (05-24-2015), jedi_sol (05-29-2015), mikeyjd (05-24-2015), MobilOne (05-26-2015), niky (05-26-2015), oil pan 4 (05-24-2015), UltArc (05-24-2015), whatmaycome14 (05-24-2015), Xist (05-26-2015)
