When I left the car with my mechanic before the weekend we had a quick look, and the heater core hose has an internal diameter of only ~22mm, while the inline coolant heaters I've found are for hoses with 28mm or more
I did find that DEFA makes a heater for the PSA 1.1 engine (part #411766), which looks like this:
but it is 3-4 times more expensive than the heater I found.
Maybe, I'll send an email asking if they could modify the heater casing for my needs. If not, then Theodor won't have get an engine heater
What matters is
where you're going, not
how fast.
