Old 05-25-2015, 09:23 PM   #19 (permalink)
PremierSprinter
Steel subframe is out. I took a few more measurements and it looks like the center hole for the ball joints from the MK4 and MK5 are within an eighth of an inch apart; however, the outer holes are not spaced the same. I'm going to have to drill new holes in the control arms if the MK5 balljoints won't fit into the MK4 knuckles.
The Following User Says Thank You to PremierSprinter For This Useful Post:
deejaaa (05-25-2015)
